GSM AT commandset |
The following AT commands have been
confirmed to work on a Nokia connected to a PC |
Call Control |
Phone Control Commands |
ATA Answer Command
ATD Dial Command ATH Hang Up Call ATL
Monitor Speaker Loudness ATM Monitor Speaker Mode
ATO Go On-Line ATP Set Pulse Dial as Default
ATT Set Tone Dial as Default AT+CSTA Select Type
of Address AT+CRC Cellular Result Codes |
AT+CBC Battery Charge
Level AT+CGMI Request Manufacturer
Identification AT+CGMM Request Model Identification
AT+CGMR Request Revision Identification AT+CGSN
Product Serial Number Identification AT+CMEE Report
Mobile Equipment Error AT+CPAS Phone Activity Status
AT+CPBF Find Phone Book Entries AT+CPBR Read
Phone Book Entry AT+CPBS Select Phone Book Memory
Storage AT+CPBW Write Phone Book Entry AT+CSCS
Select TE Character Set AT+CSQ Signal Quality |
Data Card Control Commands |
Computer Data Card Interface Commands
ATI
Identification ATS Select an S-register ATZ
Recall Stored Profile AT&F Restore Factory
Settings AT&V View Active Configuration
AT&W Store Parameters in Given Profile
AT&Y Select Set as s Powerup Option AT+CLCK
Facility Lock Command AT+COLP Connected Line
Identification Presentation AT+GCAP Request Complete
Capabilities List AT+GMI Request Manufacturer
Identification AT+GMM Request Model Identification
AT+GMR Request Revision Identification AT+GSN
Product Serial Number Identification |
ATE Command
Echo ATQ Result Code Suppression ATV Define
Response Format ATX Response Range Selection
AT&C Define DCD Usage AT&D Define DTR
Usage AT&K Select Flow Control AT&Q
Define Communications Mode Option AT&S Define
DSR Option AT+ICF DTE-DCE Character Framing
AT+IFC DTE-DCE Local Flow Control AT+IPR Fixed
DTE Rate |
Reporting Options Commands |
Network Communication Parameter Commands
AT+CLIP Calling Line
Identification Presentation AT+CR Service Reporting
Control AT+DR Data Compression Reporting AT+ILRR
DTE-DCE Local Rate Reporting |
ATB Communications
Standard Option AT+CBST Select Bearer Service Type
AT+CEER Extended Error Report AT+CRLP Radio Link
Protocol AT+DS Data Compression |
Miscellaneous Commands |
SMS Commands |
A/ Re-Execute Command
Line AT? Command Help AT*C Start SMS Interpreter
AT*T Enter SMS Block Mode Protocol AT*V Activate
V.25bis Mode AT*NOKIATEST Test Command AT+CESP
Enter SMS Block Mode Protocol |
SMS Text Mode
AT+CSMS Select Message Service AT+CPMS
Preferred Message Storage AT+CMGF Message Format
AT+CSCA Service Centre Address AT+CSMP Set Text
Mode Parameters AT+CSDH Show Text Mode Parameters
AT+CSCB Select Cell Broadcast Message
Types AT+CSAS Save Settings AT+CRES Restore
Settings AT+CNMI New Message Indications to
TE AT+CMGL List Messages AT+CMGR Read Message
AT+CMGS Send Message AT+CMSS Send Message from
Storage AT+CMGW Write Message to Memory AT+CMGD
Delete Message SMS PDU Mode AT+CMGL List
Messages AT+CMGR Read Message AT+CMGS Send
Message AT+CMGW Write Message to
Memory |
